16 years agoProduce 5v output?
Hi all, I am using expansion header on my DE1 FPGA board to output my pwm signals. However, the output signals are 3.3v only. How do I set it to output 5v? I can't seem to find it in pin assign...
16 years agoExcept for a few legacy devices, Altera programmable logic is limited to 3.3V I/O voltage. The I/O cells also aren't 5V tolerant. To achieve 5V output, you need level shifters. The 3.3V LVCMOS I/O standrad can however drive 5V TTL with a sufficient high level. Many 5V supplied logic devices and peripherals can be reliably operated this way.
