17 years agoProblems with SRAM
I`have downloaded and installed Altera`s University program IP`s which are made for DE1 and DE2 boards. I`am using the Cyclone II FPGA Starter board, which is same as DE1 board (as I saw), and I have...
17 years agoHi Stanislav,
how do you connect to the SRAM? You probably need to use a tristate bridge. The SOPC Builder should also feature an SOPC component for your SRAM, which has to be connected to the tristate bridge. So you probably have to adapt the SRAM settings from the DE1 boards to your board. Probably it's best to have a look into the examples that are available for you starter kit, which you can download from the Altera webpage. Cheers, Alex
