17 years agoproblems with pin assignments
Using the assigments file, I'm working in a simple design which contains NIOS+SRAM+Flash+UART. I've assigned to TX a signal called HC_UART_TXD, When I run the project I can see message "Hello W...
17 years agocompilation was successful, thanks a lot!!!!!!
best regards
