17 years agoproblems with pin assignments
Using the assigments file, I'm working in a simple design which contains NIOS+SRAM+Flash+UART. I've assigned to TX a signal called HC_UART_TXD, When I run the project I can see message "Hello W...
17 years agoI've done this,
nCEO --> from programming pin --> to regular I/O other active parallel pins --> from programming pin --> to regular I/O data[7..2] --> from input tristated --> to regular I/O Compilation was successful
