17 years agoproblems with pin assignments
Using the assigments file, I'm working in a simple design which contains NIOS+SRAM+Flash+UART. I've assigned to TX a signal called HC_UART_TXD, When I run the project I can see message "Hello W...
17 years agoGo to Device and Pin Options and set nCEO to be used as regular IO after config.
