15 years ago
Problems with JTAG code
I'm starting to work with an FPGA, and I'm trying to run the first example
of the NIOS II IDE.
After I create and build the project, I give it the command to run, after which I receive the following message on the console:
"there are no nios ii cpus with debug modules available which match the values specified. please check that your pld is correctly configured, downloading a new sof file if necessary."
And then, it opens the Quartus II program. I add the standard NIOS II .sof file, and then when I try to load it into the device, this appears:
"error: can't configure device. expected jtag id code 0x020b40dd for device 1, but found jtag id code 0x020b30dd.
error: operation failed"
What might be causing this, and how can I fix it? I'm working on a Cyclone II, in a machine running Windows XP.
    --- Quote Start ---
    How can I check if my project is using that number?
    --- Quote End ---
    Assignments->Device
    The GUI will show you what you have selected.
    --- Quote Start ---
    And where in the board design documents can I find it? The data sheet, the schematics or another document?
    --- Quote End ---
    I would hope so. Can you see the top of the FPGA package? If so, its printed on there too.
    --- Quote Start ---
    And, if the project is using a different code, how can I change it to the correct one?
    --- Quote End ---
    Change the Assignments->Device settings to the correct part number and recompile the project. Changing the part number might cause Quartus to reset all assignments, so you'll have to figure out which ones are important and set them up again for the new project. One way to determine what the current settings are, is to have Quartus generate a Tcl file for the current design using Project->Generate Tcl File For Project.
    Cheers,
    Dave
    Thanks for replying. But, I still have questions.
    How can I check if my project is using that number? And where in the board design documents can I find it? The data sheet, the schematics or another document?
    --- Quote Start ---
    --- Quote End ---
    You have the wrong Cyclone device type selected; the JTAG code for each device is different.
    Check your board design documents for the correct part number, and then check your project is using that part number.
    Cheers,
    Dave
