15 years agoProblems with JTAG code
I'm starting to work with an FPGA, and I'm trying to run the first example of the NIOS II IDE. After I create and build the project, I give it the command to run, after which I receive the fo...
15 years ago --- Quote Start --- How can I check if my project is using that number? --- Quote End --- Assignments->Device The GUI will show you what you have selected. --- Quote Start --- And where in the board design documents can I find it? The data sheet, the schematics or another document? --- Quote End --- I would hope so. Can you see the top of the FPGA package? If so, its printed on there too. --- Quote Start --- And, if the project is using a different code, how can I change it to the correct one? --- Quote End --- Change the Assignments->Device settings to the correct part number and recompile the project. Changing the part number might cause Quartus to reset all assignments, so you'll have to figure out which ones are important and set them up again for the new project. One way to determine what the current settings are, is to have Quartus generate a Tcl file for the current design using Project->Generate Tcl File For Project. Cheers, Dave
