eamun1
6 years agoProblems with design example Low Latency Ethernet 10G MAC Intel FPGAIP
I've created the Design example base on the Low Latency Ethernet 10G MAC Intel FPGAIP, with the following parameters I open the project and suscessfully compile it, I try to run the simulation a...
Deshi_Intel
6 years agoHi,
If you can see the waveform output file (vsim.wlf) generated in your sim project, you are all set.
I am guessing you didn't enable or pull out the sim waveform windows during sim run. Not sure why the sim waveform window doesn't pop up automatically.
Now, you can go back to Modelsim
- File -> Open -> vsim.wlf
- It should bring you to sim run windows
- Right click on the tb_top -> add to -> wave -> all items in region
- The sim waveform window will pop up with all signals activity captured
dlim
