eamun1
6 years agoProblems with design example Low Latency Ethernet 10G MAC Intel FPGAIP
I've created the Design example base on the Low Latency Ethernet 10G MAC Intel FPGAIP, with the following parameters I open the project and suscessfully compile it, I try to run the simulation a...
Deshi_Intel
6 years agoHI,
Good. Things is working on your side as well.
From my end, I did able to see the Modelsim waveform window pop up as well but I am not sure when it pop up.
Why not you let the sim run finish at your end first to see whether the Modelsim Waveform Window pop up or not ?
dlim
