eamun1
6 years agoProblems with design example Low Latency Ethernet 10G MAC Intel FPGAIP
I've created the Design example base on the Low Latency Ethernet 10G MAC Intel FPGAIP, with the following parameters I open the project and suscessfully compile it, I try to run the simulation a...
Deshi_Intel
6 years agoHI,
Good luck in trying again. My sim run is in progress as well. I will check the result in tomorrow.
Nope, I am not referring to starter edition. That's the Intel FPGA free edition with even lower performance.
I am referring to Special Edition (SE). More powerful and expensive edition. You can checkout below link.
For further detail, you may want to consult back Mentor Graphic.
dlim
