eamun1
6 years agoProblems with design example Low Latency Ethernet 10G MAC Intel FPGAIP
I've created the Design example base on the Low Latency Ethernet 10G MAC Intel FPGAIP, with the following parameters I open the project and suscessfully compile it, I try to run the simulation a...
eamun1
6 years agoHello, thank you for your help, I ran it about an hour, I stopped manually since I thought it was frozen. I will try to run the simulation again. When you talk about Modelsim SE you mean to Stater Edition? Because that is the one I have install already
