eamun1
6 years agoProblems with design example Low Latency Ethernet 10G MAC Intel FPGAIP
I've created the Design example base on the Low Latency Ethernet 10G MAC Intel FPGAIP, with the following parameters I open the project and suscessfully compile it, I try to run the simulation a...
Deshi_Intel
6 years agoHi,
I just gotten feedback from Intel Engineering team.
Sim run with Modelsim Intel FPGA may take 8 to 12 hours to complete.
- May I know how long did you run the sim ? Else I suggest you to rerun the sim again
- I will also try run the sim from my side overnight to check the result
If you need faster sim run time, then the better option will be to use Modelsim SE version instead.
dlim
