eamun1
6 years agoProblems with design example Low Latency Ethernet 10G MAC Intel FPGAIP
I've created the Design example base on the Low Latency Ethernet 10G MAC Intel FPGAIP, with the following parameters I open the project and suscessfully compile it, I try to run the simulation a...
Deshi_Intel
6 years agoHI,
Thanks. I can see your attachment image now.
- Can you confirm are you using Cyclone 10 GX FPGA or which FPGA ?
- Also, can you share screen shot of the Ethernet "IP" page instead of "example design" page. It's good to know what setting that you configured
So, Modelsim 10.6d still failed ya.
- Have you looked into the sim log error message to locate the design files to see they are really missing in project folder or so ?
- Btw, I also found below known issue in the past. You can try shorten your Win Quartus project folder path and see
dlim
