eamun1
6 years agoProblems with design example Low Latency Ethernet 10G MAC Intel FPGAIP
I've created the Design example base on the Low Latency Ethernet 10G MAC Intel FPGAIP, with the following parameters I open the project and suscessfully compile it, I try to run the simulation a...
Deshi_Intel
6 years agoHI,
I can't see the pic attachment in this forum. The only attachment available is the log file only.
- May I know are you using Arria 10 or Stratix 10 FPGA for the sim run ?
- Looking at your sim log file. The error is complaining it can't find certain design files in your Quartus project folder. Have you verified the design files is there in folder or missing ?
- The other thing that I noticed is you are using Quartus v19.1 pro but pair with Modelsim 10.5b. Based on Quartus v19.1 Pro release note,you should be using Modelsim 106d instead to avoid sim tool compatibility issue.
- Another possibility that I can think off is maybe either your Quartus project or Ethernet example design is corrupted.
My debug suggestion is :
- Create a new Quartus project and generate new Ethernet example design
- Then run sim again using Modelsim 10.6d as your example design is generated from Quartus pro v19.1
dlim
