14 years agoProblem with Zip file
Hello guys, Good day. I have problem after download zip file into flash. I already download .sof file and zip file without any error. Just warnings appear. Should appear at LCD display is " We...
14 years ago --- Quote Start --- If you download your software through JTAG (which is the case when using "Run as Nios II Hardware") you should just put all your sections to the main RAM (which is SDRAM on your project). --- Quote End --- Hi Dixiwen, Thanks for your concern. First, I download my software through UART (set stdin,stdout,stderr to UART) because I have rs232 cable. I read altera document, it said that if we use rs232 cable,we have to set the stdin,stdout and stderr to UART. Is it right? --- Quote Start --- If you have some sections in Flash then the nios downloader will attempt to write data to flash and will fail with a verify error. --- Quote End --- Second, I have two sections in Flash (EPCS and CFI). I write .sof file first using EPCS. Then, I write .zip file using CFI. What do you mean by will fail with a verify error? Thanks in advance
