14 years agoProblem with Zip file
Hello guys, Good day. I have problem after download zip file into flash. I already download .sof file and zip file without any error. Just warnings appear. Should appear at LCD display is " We...
14 years agoDear Daixiwen,
I check the ro_zipfs_base parameter and ro_zipfs_offset. The value is same with your suggestion. When I run at Nios, Nios => Run As => Nios II hardware. The error occur which is failed download the elf file. The error occur at address 0x1400000 and 0x140FFFF (refer my attachment). When I check these two address at SOPC, it related with CFI_FLASH (0x1400000). While I'm not sure for address 0x140FFFF. Do you have any suggestion or ideas related with this problem ? :(
