14 years agoProblem with Zip file
Hello guys, Good day. I have problem after download zip file into flash. I already download .sof file and zip file without any error. Just warnings appear. Should appear at LCD display is " We...
14 years agoOkay I didn't know you had both a CFI and an EPCS. If you put the zip file into the CFI flash then the rozipfs should work without modification.
The ro_zipfs_base parameter should be the CFI component base address, as seen in SOPC builder, and the ro_zipfs_offset should be the offset of the zip file as seen in the flash programmer. If you only have the zip file in the CFI I guess the offset should be 0.
