MKuli5
7 years agoProblem with using On-Chip Flash IP Core for programming CFM0 on MAX10.
Hi! I try to realize a remote upgrade system for MAX10(10M08DCU324C8G). I use On-Chip Flash IP Core for access to internal flash memory. Regretfully I could not get access to CFM0 because bit 9(CFM...
ShafiqY_Intel
7 years agoHi MKuli5,
You need to disable write protection CFM0 in order to get access.
For example:
Your CFM0 is use Sector ID 1 & Sector ID 2.
If you look at On-Chip IP Control Register, Bit Offset 23 & 24 is write protection for CFM0 (Sector ID 1 & Sector ID 2).
Thus, you need to set these bit offset to 0.
I hope this will help. Let me know if you need more understanding.
Thanks.😉
