17 years agoProblem with the Compact Flash Controller
Hi, I've got a Nios system compiling just fine with several peripherals, but I've got some output pins stuck at VCC and GND. They're all from the Compact Flash controller in sopcbuilder. I ...
17 years agoHa, I noticed that error about two seconds after I hit "Post."
Regardless, so if I'm understanding you correctly, would that mean that there are only 2^3 = 8 relevant addresses in an entire Compact Flash card of any size? Surely I'm missing something here. Anyway, if the hardcoded pins are in fact correct, they will not need to be connected to Cyclone III device pins then, correct? Thanks a million, Jon
