8 years agoProblem with SMBUS read stop bit
I have a custom platform with an Arria 10 interfacing to some voltage regulators over SMBUS. Writes to those devices appear to work, but the protocol analyzer I have attached indicates to me that reads are failing because the initial write command also issued a stop bit which causes the transaction to abort. I can read and write all devices on the bus cleanly through the manufacturer's programming dongle and can see that its protocol does not use those stop bits.
I feel that this must be due to something in the bitmasks that I'm using in the linux ioctl configuration or something, but haven't been able to figure it out.No RepliesBe the first to reply
