12 years agoProblem with SDRAM: works fine on Cyclone II but not on Cyclone IV
Hi forum, This problem is getting me crazy! I have two boards, both with an Alliance AS4C8M16S-6TIN SDRAM, one has a EP2C5T144C8N and the other a EP4C15E22C7N. I'm using Qsys SDRAM controller t...
12 years agoHere's the datasheet:
http://www.alliancememory.com/pdf/dram/128m-as4c8m16s.pdf My PLL has 2 clocks, both 96MHz but one has a -3.0ns phase shift, which works on Cyclone II. I'll do some testing with -5.4ns phase shift and lower frequencies. EDIT: I got it working on Cyclone IV by compiling the Cyclone II project and changing the device and pin locations, any clue if there is a setting that i'm missing?
