15 years agoProblem with port mapping in Quartus
Hello, I am trying to model a two dimensional array of registers using port mapping in quartus. I have first designed a five stage shift register for which I am getting the desired result i.e., th...
15 years agoI have figured out the problem. In this design both the CLK and the CE have 16 fan outs. If I change atleast one such that its fan-out becomes 8 or less then the problem is sorted. However, since I am going to use this block as a part of a larger design I cannot have more than one clock. I, therefor, planned to split the fan-out of CE. I designed a CE block which produces two high outputs if the input which is the original clock enable is high. Now I used the Input and the output of these blocks as CEs. The code is given here
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity Memoryblock is Port ( Input : in STD_LOGIC_VECTOR (15 downto 0); Output : out STD_LOGIC_VECTOR (15 downto 0); CLK : in STD_LOGIC; -- CE1 : inout std_logic; -- CE2 : inout std_logic; CLR : in STD_LOGIC; CE : in STD_LOGIC); end Memoryblock; architecture Behavioral of Memoryblock is signal CE1 : std_logic; signal CE2 : std_logic; component MEMBLOCK is Port ( Input : in STD_LOGIC; CLK : in STD_LOGIC; CLR : in STD_LOGIC; CE : in std_logic; Output : out STD_LOGIC); end component; component ClockEnable is port(CE : in std_logic; CE1 : out std_logic; CE2 : out std_logic); end Component; begin C : ClockEnable port map(CE, CE1, CE2); A0 : MEMBLOCK port map( Input(0), CLK, CLR, CE, Output(0)); A1 : MEMBLOCK port map( Input(1), CLK, CLR, CE, Output(1)); A2 : MEMBLOCK port map( Input(2), CLK, CLR, CE, Output(2)); A3 : MEMBLOCK port map( Input(3), CLK, CLR, CE, Output(3)); A4 : MEMBLOCK port map( Input(4), CLK, CLR, CE, Output(4)); A5 : MEMBLOCK port map( Input(5), CLK, CLR, CE1, Output(5)); A6 : MEMBLOCK port map( Input(6), CLK, CLR, CE1, Output(6)); A7 : MEMBLOCK port map( Input(7), CLK, CLR, CE1, Output(7)); A8 : MEMBLOCK port map( Input(8), CLK, CLR, CE1, Output(8)); A9 : MEMBLOCK port map( Input(9), CLK, CLR, CE1, Output(9)); A10 : MEMBLOCK port map( Input(10), CLK, CLR, CE1, Output(10)); A11 : MEMBLOCK port map( Input(11), CLK, CLR, CE2, Output(11)); A12 : MEMBLOCK port map( Input(12), CLK, CLR, CE2, Output(12)); A13 : MEMBLOCK port map( Input(13), CLK, CLR, CE2, Output(13)); A14 : MEMBLOCK port map( Input(14), CLK, CLR, CE2, Output(14)); A15 : MEMBLOCK port map( Input(15), CLK, CLR, CE2, Output(15)); end Behavioral; The problem is if I use the CE1 and CE2 as signals then the CE has again a fan-out of 16. I have to use them as inout ports which is a little difficult as the block is part of a larger design. How can I sort my problem out? Please help!!!
