15 years agoProblem with port mapping in Quartus
Hello, I am trying to model a two dimensional array of registers using port mapping in quartus. I have first designed a five stage shift register for which I am getting the desired result i.e., th...
15 years agoThe only possible issue with the code, is the fact you have the CE on the same line as a the clock. Usually it is common to separate a clock enable from the clock, ie:
if rising_edge(clk) then
if CE = '1' then
end if;
end if;
But I doubt this is causing the issue. There is otherwise nothing wrong with the code. Im guessing the problem is elsewhere. Wherre are you seeing the problem? RTL simulation? gate level simulation? on the chip?
