10 years agoproblem with pin placement for ddr2_dimm_clk[*]/clk_n[*]
I have a Stratix III dev kit and ran through the emi_tut_qdr.pdr External Memory tutorial just fine (https://www.altera.co.jp/ja_jp/pdfs/literature/hb/external-memory/emi_tut_qdr.pdf). This example d...
10 years agoI put in a service request about this issue and the response from Altera was that those pins indeed do not support differential input because the pins for _ck[1]/_ck_n[1] and _ck[2]/_ck_n[2] are not on dedicated TxRx channels. My question is then why did these pin assignments work for the example design in emi_tut_qdr.pdf but not for this design? Also does the DDR2 DIMM need 3 clocks or would one clock be sufficient?
Erin
