14 years ago
Problem with length of register in multiplication op
I'm working on a design which contains the following lines,
signal acc : unsigned (7 downto 0) ;
process ()
if(i /= 7) then
acc <= acc * acc;
i <= i + 1;
I am aware that in the above code, at each counter value the value of the acc is being doubled and is mismatching with the declared accumulator length and the compiler throws an error of mismatch. Is there any other way of getting through this type of situation ?
Siva
1 Reply
    I think I found where I was doing mistake folks, actually its pretty basic
    declaring the accumulator length according to the counters maximum value and lodading,storing the multiplication values in particular lengths solved the problem, time for me to revise my basics.
    Siva
