14 years agoProblem with JTAG
Hi, I use an USB Blaster cable to program an EP3C25U256 an EPCS16 with quartus II web edition 11.1. First, I programmed several times without any problem and after a while, i received an error ...
14 years agoI think you should first ensure that the USB-Bluster or other cable else OK, for example, change a board and go a test. Then test the pins of JTAG to make sure the signals is OK when running the JTAG.
