8 years agoProblem with FSM on Hardware testing
Hello All, I have designed Manchester Decoder in System Verilog using 2 always block method. But in testing on hardware, I am analyzing outputs in SignalTap and it is found that after reset one...
8 years agoyes, divyaganti it is stuck in reset.
But I got a solution for this issue. As I have taken input from a gateway, I have used that signal directly in FSM, but now I have taken a flop of that signal and then used that flop in FSM and It starts working. Again thank you to both of you for your warm replies.
