8 years agoProblem with FSM on Hardware testing
Hello All, I have designed Manchester Decoder in System Verilog using 2 always block method. But in testing on hardware, I am analyzing outputs in SignalTap and it is found that after reset one...
8 years ago --- Quote Start --- 1.Have you simulated the code? (This message was posted on behalf of Intel Corporation) --- Quote End --- thank you sir for your reply. Yes I have simulated the code in Quartus 16.1 --- Quote Start --- 2.try to use altera quartus template. --- Quote End --- You mean to say that I should use the same method as given in Altera Quartus template. ?
