11 years agoProblem with Data Integrity & Clock between 2 FPGAs
Hi I have a problem with data integriry & clock between 2 FPGAs. A scheme of my design is inserted at the end. My design consists of 2 Cyclone III FPGAs. Each FPGA has several clock domains, eac...
11 years ago --- Quote Start --- However for understanding the problem, another question raised in my mind: You said I should enter reasonable constraints for IO delay constraint. What do you mean by reasonable here? In my example, assume I want to use clk1 (no phase shift) to feed FPGA-1. How should I set my first trial of IO constraint? More specifically, what are reasonable t_co_min, t_co_max, t_su & t_h values in the SDC file? What are the starting point values? --- Quote End --- You need to learn how to use TimeQuest. The TimeQuest GUI shows you the timing waveforms for your given set of constraints, including by how much you fail. So you could start off with 0ns constraints and see by how much you fail. However, after you've done that once for an FPGA family, you'll know what "reasonable" means, so from that point on, you use reasonable constraints. Take a look at the figures in this document - they show screen captures from TimeQuest https://www.ovro.caltech.edu/~dwh/correlator/pdf/timequest_quad_spi_flash.pdf https://www.ovro.caltech.edu/~dwh/correlator/pdf/timequest_quad_spi_flash.zip Cheers, Dave
