11 years agoProblem with Data Integrity & Clock between 2 FPGAs
Hi I have a problem with data integriry & clock between 2 FPGAs. A scheme of my design is inserted at the end. My design consists of 2 Cyclone III FPGAs. Each FPGA has several clock domains, eac...
11 years agoI applied input_delay & output_delay constraints, thanks to your SDC guidelines.
In Cyclone III spreadsheets, t_su is negative. I inserted its value as a positive value. t_h is copied from spreadsheet. t_co is calculated according to Method-2 of AN-366. After synthesis & programming FPGAs, still I have problem with data corruption. What could cause problem? Is sending out clock from a normal IO pin a good design practice? One more question: Isn't it better that I feed FPGA-1 with clk1, instead of clk2? i.e. without 180 degree phase shift? is this phase shift in compliance with our constraints? What about output currents? is there a guideline to set output current? specially for clocks? Thanks
