16 years agoProblem with CycloneIII custom board
Hi, I have a crazy problem with my design and I have no idea what I can do. I have designed a custom FPGA board. The board has an EP3C120F484 in combination with an EPCS64 config device. ...
16 years agoSeriously, no forum member would be able to detect this kind of problems from a distance. Unfortunately this things happens.
Apart from a thorough visual inspection of layout and gerber files, PCB connection errors (open and short) can be detected by checking the gerber data against the net list with a full-featured gerber tool. Also the PCB manufacturer should be able to detect these problems, if you supply an IPC-356 net list with the gerber data.
