17 years agoProblem with Cyclone III Remote Update IP?
Hi all 1) Anyone who have successfully used the Cyclone III Remote Update IP? 2) Is this ok? : Cpu run at 50MHz and IP run at 40MHz. The IP is connected directly without using a bridge ...
17 years agoI have successfully used the Cyclone III update.
Some thoughts: Can you try running it at 40 MHz just to be certain the 50 Mhz main clock is not the problem? The basic steps that are working for me: 1. Set image address shifted by 2 bits to register 0x04. 2. Disable watchdog by writing 0 to register 0x03. 3. Write 1 to register 0x20. For serial config mode, shifting the address by 2 is required. I seem to recall some Altera sample code shifting by 3, but I think this may have been for parallel configuration.
