10 years agoProblem with configure Stratix III with AS using EPCS128
Hi! I have a problem with configure my Stratix III EP3SL340H1152I3. I programming EPCS128 device through FPGA via JTAG normaly, with verification sucsessfuly. But after power off and power on a...
10 years ago --- Quote Start --- I found what was wrong. Ewerything about my hardware was ok, exept one thing: EPCS was not original altera divice and when FPGA begin to load data, it asked divice ID first (i think so). I found another guy had same problem, but with configure ARRIA II. Solution is simple: when i create JIC file, there are two options "Disable EPCS ID check" and "Disable AS mode CONF_DONE error check". I turned them on and configuration passed correctly =) But i still don't understand how could i change divice ID with wire or probe conneccted to line)) Thank you for taking part in solving this problem --- Quote End --- I do not think you are able to change the device ID wwith wire or probe. Each device should have their own unique ID :)
