10 years agoProblem with configure Stratix III with AS using EPCS128
Hi! I have a problem with configure my Stratix III EP3SL340H1152I3. I programming EPCS128 device through FPGA via JTAG normaly, with verification sucsessfuly. But after power off and power on a...
10 years agoI found what was wrong.
Ewerything about my hardware was ok, exept one thing: EPCS was not original altera divice and when FPGA begin to load data, it asked divice ID first (i think so). I found another guy had same problem, but with configure ARRIA II. Solution is simple: when i create JIC file, there are two options "Disable EPCS ID check" and "Disable AS mode CONF_DONE error check". I turned them on and configuration passed correctly =) But i still don't understand how could i change divice ID with wire or probe conneccted to line)) Thank you for taking part in solving this problem
