10 years agoProblem with configure Stratix III with AS using EPCS128
Hi! I have a problem with configure my Stratix III EP3SL340H1152I3. I programming EPCS128 device through FPGA via JTAG normaly, with verification sucsessfuly. But after power off and power on a...
10 years agoThanks for replying, Alex.
EPSC is close enough to FPGA, about 1-2cm. I've already tried to add series resistor to DATA line, still doesn't work I caught signal on DATA pin when EPCS start to configure after i connect probe to line. And another strange thing: it started configuration when i soldered long wire to DATA pin (with another end left not conected like aerial) and resistor 56 kOhm to GND. :)
