8 years agoproblem with aocl install
I tried to compile main.cpp from an example provided by Altera (vector_add), and the compilation failed. it seems the compilation failed because ths FCDs wasn't installed. but when i try to install the drivers (with aocl install) i get the following message : "error: cannot open service control manager make sure you are running with Administrator privileges" how can i issue this problem ? thanks for your helpNo RepliesBe the first to reply
