14 years agoProblem with Altera DSP Builder and Matlab
Sir I have: OS: Windows 7 (64bit) Matlab : 2012a(32bit) Altera Quartus II (web edition) : 11.0sp1 (32bit) ModelSim SE : 10.0c(32bit) FPGA kit: Altera Cyclone (EP1C12Q240C8) (Cyclone Fa...
14 years agoYou should only have one altelink2 file on your path. If you have more than one then you should remove extra ones as they may interfere.
To do this, click the File menu and click "Set Path...". Remove any paths that point into versions of DSP Builder other than 11.0sp1. In addition, type edit classpath.txt at the MATLAB prompt and check that there are no references to a dspb_sblocks.jar other than the 11.0sp1 version. When you save this file, you will have to restart MATLAB for it to have any effect.
