16 years ago
Problem with a simple bi-direcional counter simulation
Hello this is my code
module count_moda
   # (parameter modulus = 100)
    input clk, aclr_n, updown,
    output reg  q
initial q = 0;
always @(posedge clk, negedge aclr_n)
begin
    if (!aclr_n)
        q <= 0;
    else    begin
        q <= q + (updown? 1'b1 : -1'b1);
        if (q == modulus-1)
            q <= 8'd0;
    //    if (q == 0)
        //    q <= modulus -1;
        end
end
endmodule
The way it is right now it restarts when 99 is reached, then it starts to count up untill 10 when my updown signal goes to 0 and it starts decremetating to 9, 8 etc.. untill it goes to a negative value!
But i want to go back to 99 when i reach 0 in the decrematating mode, don't know how to solve it
If i uncomment the second if my result is always 0 or 99.
    > if (q == modulus-1) > q <= 8'd0;
    this script should be
    if( updoun )
    begin
    if( q == (modulus-1) )
    q <= 8'h0;
    end
    else
    begin
    if( q == 8'h0 )
    q <= (modulus-1) ; end
    I think this is obvious too.
    you haven't written reset logic for negative direction.
    You can't perform the overflow/underflow operation correctly without using the updown input, it seems so obvious...
