13 years agoProblem using VHDL from a project lower in the heirarchy in an upper level
I created a very simple dual edge detector using D flip flops and a few logic gates. I created this using Megafunctions LPM_DFF, LPM_XOR, LPM_INV, and LPM_AND symbols. This project compiles and cre...
13 years ago --- Quote Start --- Thanks for you quick help. Your answer provided a key clue. I indeed had to use LP_FF. I verified this using the LPM_PACK file that that the Quartus generated VHDL said to add if you used the work declaration. Again thanks for the help. --- Quote End --- You're welcome. --- Quote Start --- I still have one remaining problem that you might be able to shed some light on. When I simulate or compile the lower level block everything is find. When I insert this block in a higher level design and try to compile, I get an error saying all my inputs are not driving logic. All I did was connect input and out pins to the symbol, which compiled and simulated without problems. Any advice?? --- Quote End --- In your top-level design, are you connecting the ports on your component to signals declared in the top-level architecture, or to ports in the top-level architecture? If you are only connecting to signals, and those signals come from "nowhere", then that would be the source of your problem. In a simulation, you would see those signals as RED in the waveform viewer if they are not being driven by something. That's just a guess though ... do you have a working simulation with testbench? Cheers, Dave
