18 years agoproblem using cyclone ep1c3t144
Hello, guys i have a problem and i would like to discuss it with you, I have designed a pcb which has a 10bit ADC and sends LVDS signals to ALTERA's EP1c3t144, the problem is the following , i use...
18 years agothanx for replying, You said that"""In one case, I finally ended up in using a custom LVDS receiver based on altddio_in and a shift register"" you mean that you have made a modified programm in vhdl for altddio_in? and you also put a shift register? did it work?
