DRainey
6 years agoProblem programming configuration flash connected to Arria 10
I am having a problem programming a configuration flash connected to the Arria 10 FPGA. We are using CvP to boo the FPGA which is connected to the PCIE bus with a Linux host computer. The peripheral ...
JohnT_Altera
6 years agoHi,
I would recommend you to use "https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-gen-sfi.pdf" Generic Serial Flash Controller IP which should let you make the setting for the specific flash you are using.
