15 years agoproblem on insatntiated pll (EP2C5F256I8)
Hi, i have used EP2C5F256I8 in my project,which requires 16 mhz clk to be converted into 32 mhz clk and i have generated a pll using megawizard.I would like to know whether - the output ...
15 years ago --- Quote Start --- Hi, i have used EP2C5F256I8 in my project,which requires 16 mhz clk to be converted into 32 mhz clk and i have generated a pll using megawizard.I would like to know whether - the output of the pll must be locked. - and i have seven modules that is to be driven by pll clk, can it be connected by signal from instantiated pll block. Kindly help me by providing some information. Thank You. --- Quote End --- Hi, if you would like to check whether the pll is locked or not, you can define a lock signal with the megawizard. When you assign the signal to an FPGA pin your can check it easy with a scope. You can connect all your modules to the pll output. Kind regards GPK
