15 years agoproblem of lpm_mux in megafunction
I wish to know the sel function in megafunction of lpm_mux , is it edge trigger or level trigger ??
Sorry, I posted the wrong question ((
Here is what I meant to ask: Is it possible to use lpm_mux in pipeline mode to multiplex two stream of 8-bit data @ 50MHz each into a single stream of 8-bit data @ 100MHz ? Can lpm_mux on the first rising edge of the clock select the first 8-bit stream and on the second rising edge of the clock select the second 8-bit stream and so on? I suppose that in this case Sel is ignored by lpm_mux? - Altera_Forum
No. Its just a mux, Sel is always used and never ignored. You could easily do it though by having a toggle bit toggling at 2x data rate selecting the alternating halves of the wrod.
