8 years agoProblem in Inter FPGA Transfer
hi, I am having a customized board with 2 Stratix V FPGA on it. i wanted to transfer the data from one FPGA to another directly ( Pin to Pin ) without ant protocol. The clock rate is 10 Mhz . ...
8 years ago --- Quote Start --- hi, I am having a customized board with 2 Stratix V FPGA on it. i wanted to transfer the data from one FPGA to another directly ( Pin to Pin ) without ant protocol. The clock rate is 10 Mhz . I am finding that the data received is not same as what i had sent. The problem is in the SDC file in which i had given the INPUT_DELAY and OUTPUT_DELAY commands. Kindly suggest me how to find the accurate delays to be given in SDC file and what other commands i should enter to get the correct data . Saurabh --- Quote End --- You need to describe the protocol you are using in more detail. Is it a single data line, as in a serial UART but at 10MHz baud rate? Or is it embedded clock/data as would be in NRZ/NRZI encoded? Or do you have a separate clock line and data line? Or ... ? It sounds like you have more than one signal (like clock + data), as the data input/output delay on a single line would not be an issue.
