17 years agoProblem editing component SOPC
Hi, I am trying to add the DDR2 SDRAM Controller component in the SOPC builder, and next to it is a grey dot (representing an old/out of date component?) I add it and when "Controller IP Toolbench" i...
17 years agoHi,
I use ddr2 sdram controller in SOPC Builder and there is a grey dot but it works fine. May be you could have a path problem in your project, check the library position. Use this controller without the Nios II it is quite difficult, you have to write a vhdl or verilog controller to provide the correct signal to sdram controller. Instead read/write from/to sdram with Nios II it is very easy, for example: to read: var = *((volatile alt_u8 *)DDR2_SDRAM_ADDRESS_BASE + offset) to write: *((volatile alt_u8 *)DDR2_SDRAM_ADDRESS_BASE + posizione) = var Best regards Luca
