17 years agoproblem adding TSE_MAC + SGDMA
I'm having troubles adding TSE_MAC + SGDMA to interfacing with a Marvel Ethernet Phy. I'm using a Cyclone III board which I've purchased to DevBoards GmbH DBM_3C40. After download the .sof to the har...
17 years ago1 - The first thing I would try is disabling DHCP. It might be fooling you if it's got a really long timeout set. You can either do this in the system library properties or just hack the netowork_utilities.c file.
2 - Try debugging the code and seeing where it's hanging. 3 - If this is a custom built system. Did you add a system timer with the appropriate timeout? Jake
