17 years agoproblem access meories !!
hi, i try implement a design that contain one NIOSII processor and three onchip meories. first memory is used for store program. the two others memories are used to store data. i use the con...
17 years agoI thought that might be the case.
Since z2 is a pointer to int, adding 0x400 will jump to address 0x3800, not 0x2c00. Can you confirm whether you are reading the first memory correctly?
