17 years agoproblem access meories !!
hi, i try implement a design that contain one NIOSII processor and three onchip meories. first memory is used for store program. the two others memories are used to store data. i use the con...
17 years agoA couple of questions:
Are the results from the first memory what you are expecting? Is your second memory at 0x2c00 or 0x3800? If it's at 0x2c00 then the pointer z2 need only be incremented by 0x100 (as it's a pointer to a 4-byte location).
