14 years agoProbelm with DM9000A control
what should I do to drive ethernet DM9000A? I have VHDL code, which I rewrite from original Verilog DM9000A_IF in DE2-70 Ethernet demo.
entity DM9000A_IF is
generic(
W_DATA : positive := 16
port(
-- HOST Side
-- Signals fro Avalon-MM slave port "s1"
avs_s1_writedata_iDATA : in std_logic_vector(W_DATA - 1 downto 0);
avs_s1_readdata_oDATA : out std_logic_vector(W_DATA - 1 downto 0);
avs_s1_address_iCMD : in std_logic;
avs_s1_read_iRD : in std_logic;
avs_s1_write_iWR : in std_logic;
avs_s1_chipselect_n_iCS_N : in std_logic;
avs_s1_reset_n_iRST_N : in std_logic;
avs_s1_clk_iCLK : in std_logic; -- 50MHz
avs_s1_irq_oINT : out std_logic;
-- Export signal to DM9000A Chip
avs_s1_export_ENET_DATA : inout std_logic_vector(W_DATA - 1 downto 0);
avs_s1_export_ENET_CMD : out std_logic;
avs_s1_export_ENET_RD_N : out std_logic;
avs_s1_export_ENET_WR_N : out std_logic;
avs_s1_export_ENET_CS_N : out std_logic;
avs_s1_export_ENET_RST_N : out std_logic;
avs_s1_export_ENET_INT : in std_logic;
avs_s1_export_ENET_CLK : out std_logic
end DM9000A_IF;
architecture a_DM9000A_IF of DM9000A_IF is
signal clk : std_logic;
begin
avs_s1_export_ENET_DATA <= avs_s1_writedata_iDATA when avs_s1_write_iWR = '1' else (others => 'Z');
avs_s1_readdata_oDATA <= avs_s1_export_ENET_DATA when avs_s1_read_iRD = '1' else (others => 'Z');
avs_s1_export_ENET_RST_N <= avs_s1_reset_n_iRST_N;
avs_s1_irq_oINT <= avs_s1_export_ENET_INT;
avs_s1_export_ENET_CMD <= avs_s1_address_iCMD;
avs_s1_export_ENET_CS_N <= avs_s1_chipselect_n_iCS_N;
avs_s1_export_ENET_RD_N <= not avs_s1_read_iRD;
avs_s1_export_ENET_CLK <= clk; -- 25MHz
avs_s1_export_ENET_WR_N <= not avs_s1_write_iWR;
process (avs_s1_clk_iCLK, avs_s1_reset_n_iRST_N) -- For 50MHz -> 25MHz
begin
if (avs_s1_reset_n_iRST_N = '0') then
clk <= '0';
elsif (rising_edge(avs_s1_clk_iCLK)) then
clk <= not clk;
end if;
end process;
end a_DM9000A_IF;
In Quartus Pin Assignement I have these appropriate signals coresponding to datasheet. ENET_DATA <- set as bidirectional ENET_CMD ENET_RD_N ENET_WR_N ENET_CS_N ENET_RST_N ENET_INT ENET_CLK <- my 25MHz I read from registers bad values instead of values which I wrote to it. Initialization in C is also from demo. No LEDs blink. But when I try DE2-70 Ethernet demo it works.No RepliesBe the first to reply
