18 years agopreserve_hierarchy assignment
Hi, It seems like Preserve_hierarchy assignment doesn't work in my Quartus. My components are merged together (i don't want that). I could see it (one of my components) in RTL view but I couldn't...
18 years agopreserve and keep attributes are grest for specific signals that you want to see after optimization.
Another way to preserve the entire hierarchical boundary very strictly is to define the blocks as separate partitions for incremental compilation. In Project Navigator, right-click > Set as Design Partition. You don't have to make any settings for the Design Partitions if you don't care about preserving fitter results, but know that by default post-synthesis results are reused in the next compile unless you change the source code (that is, settings do not trigger recompilation). Note that making them partitions will prevent *any* cross-boundary optimizations including constant connections or unused ports - so be sure you really do want your logic blocks to be totally separate. I think the docs say something about this too... Yep here it is. From http://www.altera.com/literature/hb/qts/qts_qii51008.pdf: A design partition represents a portion of the design that you want to synthesize and fit incrementally. Incremental compilation maintains the hierarchical boundaries of design partitions, so you can use design partitions if you need to preserve hierarchical boundaries through the synthesis and fitting process. For example, if you are performing formal verification, you must use partitions with the full incremental compilation flow to ensure that no optimizations occur across specific design hierarchies. Beginning with the Quartus II software version 6.0, Altera recommends that you use Design Partition assignments instead of the Preserve Hierarchical Boundary logic option, which may be removed in future versions of the Quartus II software.
